Introduction
After following the prerequisite guides, the gear can reached by removing the lens apparatus. When the primary gear is exposed, it can simply be lifted out of the camera and inspected.
Place the camera facing upwards.
Press down on the battery cover and slide towards the front face of the camera.
Rotate the orange battery clip in the camera to release the battery.
Locate the eight outer PH 2mm screws on the device.
Using the PH00 screwdriver remove all of the screws from the camera.
Remove the clasp from the ribbon cable using the plastic spudger.
You may now remove the display.
Remove the four PH00 2.5 mm screws around the edges of the display plate.
Remove the three PH00 2 mm screws from the sides of the buttons plate and the 2.5 mm screw from the center of the buttons plate.
Lift the buttons plate out of the camera with the plastic tool.
Lift the display plate out of the camera with the plastic tool.
Check to see if there are any items stuck inside the gear.
Carefully remove items using tweezers.
If the gears are popped out of place, carefully push the gears back into its original position shown in the picture
4 other people completed this guide.
One Comment
Attention rester sur une table, et bien suivre le tutoriel. En effet, il y a des pilles, Pas la batterie: donc si vous touchez le haut de l'appareil, il y a un peux d’électricité max 4w , ce qui surprend....C'est pas dangereux mais cela surprend. Pas toucher le haut de l'appareil..... Ferreria J-C
