Installing Nikon Coolpix S51c Motherboard
  1. Installing Nikon Coolpix S51c Motherboard, Back Cover: step 1, image 1 of 2 Installing Nikon Coolpix S51c Motherboard, Back Cover: step 1, image 2 of 2
    • Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Installing Nikon Coolpix S51c Motherboard: step 2, image 1 of 1
    • Open the battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using a Phillips #00 screwdriver.
  3. Installing Nikon Coolpix S51c Motherboard: step 3, image 1 of 1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Installing Nikon Coolpix S51c Motherboard: step 4, image 1 of 1
    • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  5. Installing Nikon Coolpix S51c Motherboard: step 5, image 1 of 1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
  6. Installing Nikon Coolpix S51c Motherboard, Lens: step 6, image 1 of 3 Installing Nikon Coolpix S51c Motherboard, Lens: step 6, image 2 of 3 Installing Nikon Coolpix S51c Motherboard, Lens: step 6, image 3 of 3
    • Remove the five screws on the metal plate.
    • One of them is in a hole in the corner of the metal plate.
    • Remove the screw at the bottom of the camera.
    • Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
  7. Installing Nikon Coolpix S51c Motherboard: step 7, image 1 of 2 Installing Nikon Coolpix S51c Motherboard: step 7, image 2 of 2
    • Lift the white flap with the spudger to release the ribbon.
    • Remove the back metal plate.
  8. Installing Nikon Coolpix S51c Motherboard: step 8, image 1 of 3 Installing Nikon Coolpix S51c Motherboard: step 8, image 2 of 3 Installing Nikon Coolpix S51c Motherboard: step 8, image 3 of 3
    • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
  9. Installing Nikon Coolpix S51c Motherboard, Motherboard: step 9, image 1 of 2 Installing Nikon Coolpix S51c Motherboard, Motherboard: step 9, image 2 of 2
    • Lift two flaps with the spudger on the top of the motherboard to release ribbons.
  10. Installing Nikon Coolpix S51c Motherboard: step 10, image 1 of 2 Installing Nikon Coolpix S51c Motherboard: step 10, image 2 of 2
    • lift motherboard from the top to remove it from the camera.
Ryan
155 Reputation
6 Guides authored
Cal Poly, Team 18-24, Garner Spring 2011 Member of Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,812
