Introduction
Nikon S3500 Disassembly and how to replace your existing damaged broken LCD.
Remove 2 (4mm) screws from the bottom of the camera.
Remove 2 (4mm) screws from the bottom side of the camera.
Remove 2 (4mm) screws from the right side of the camera.
Remove 2 (4mm) screws from the left side of the camera.
Use a spudger or other plastic tool and carefully work your way around the seam and carefully Pry off the rear case.
Carefull not to loose the A/V Out cover. Remove it and set it aside.
Release the cable clamp using a spudger or similar tool.. or just use your fingernail. Be careful because the clamp breaks easily. Another way to release the cable is to just pull the LCD cable out carefully... this will automatically release the clamp without the risk of damaging the clamp
If you decide to pull the cable out make sure you hold the flex cable tightly and pull horizontal to its installed position away from the clamp. Do not hold the LCD!!! Hold only the flex cable and hold it tight.
Example photos of open and closed ziff socket clamps
Remove the LCD and Install the replacement Screen. Reverse the instructions to Assemble the unit
