Nikon Coolpix P510 Battery Removal Replacement
  1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: step 1, image 1 of 1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Battery Removal Replacement: step 2, image 1 of 2 Nikon Coolpix P510 Battery Removal Replacement: step 2, image 2 of 2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
Brian Hulsey
1,461 Reputation
6 Guides authored
3 Comments
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - Reply
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - Reply
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 -
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 32
All Time: 4,122
