Introduction
This guide will tell you how to replace your motherboard
Flip the camera upside down (have the side with the buttons facing away from you)
Look for the side with the triangle icon with three lines in it, this is the battery door. Add pressure and slide this door slightly until it clicks and pops open.
Once the door clicks, you can open it to reveal the slots holding the memory card and the battery.
Focusing on the larger slot, this holds the battery. Push the orange tab away from the slot, this will eject the old battery if one was previously inside.
Once this slot is open, you can place the new battery inside.
Remove the two 5 mm screws from the right side panel.
Remove the panel from the right side.
Remove the single 2.1 mm screw set underneath the panel.
Remove the screw to the right of the flash.
Remove the screw to the right of the microphone on the bottom. (0.124in)
Remove the four bottom screws. (0.116(fat head)-center screw, 0.112(skinny head)-other screws)
Remove the plug that connects the lens to the left side of the motherboard by firmly grasping the base of the plug and pulling gently sideways away from the camera.
Remove the three screws from the motherboard. (0.112 in screws)
Detach the orange tab with the foam on top. It will click out of place.
Carefully remove the tab that connects the flash to the motherboard from the port by gently pulling connector to the right, out of its port.
Remove the motherboard from camera body.
Replace with a new motherboard and follow the steps in reverse order to reassemble.
