Introduction
This guide will show you how to access the LCD screen to replace it, or simply clean dust from under the clear plastic cover.
There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
Two 1.5x2.5mm screws on the right side.
Two 1.5x2.5mm screws on the underside.
Two 1.5x2.5mm screw on the left side.
After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
Remove the back housing of the camera by lifting it directly up.
Note:
There are 3 locking cam-lugs along the top edge of the back plate. These slot over the top of matching very delicate moulded catches. Carefully lift and lever this top edge first.
Insert the tips of your fingers into the space between the screen and back-plate.
Gently lift the screen up and out of the frame.
5 other people completed this guide.
