Nikon Coolpix L18 LCD Screen Replacement
  1. Nikon Coolpix L18 LCD Screen Replacement, Back Cover: step 1, image 1 of 1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 LCD Screen Replacement: step 2, image 1 of 2 Nikon Coolpix L18 LCD Screen Replacement: step 2, image 2 of 2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 LCD Screen Replacement: step 3, image 1 of 1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 LCD Screen Replacement, LCD Screen: step 4, image 1 of 1
    • CAUTION! This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of descent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 LCD Screen Replacement: step 5, image 1 of 1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the logic board.
  6. Nikon Coolpix L18 LCD Screen Replacement: step 6, image 1 of 1
    • Lift the black latch connecting the LCD ribbon to the logic board.
    • Gently pull the LCD ribbon out.
Nonny
219 Reputation
2 Guides authored
Cal Poly, Team 9-23, Regan Fall 2010 Member of Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 7,078
