Introduction
In this guide, we will give you step-by-step instructions on how to detach the LCD screen so that it can be replaced or repaired.
Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
There is one screw hidden under the AV cover that also needs to be removed.
Remove the tape on the right side of the LCD screen.
Gently lift the LCD screen from its base.
Lift the black latch connecting the LCD ribbon to the motherboard.
Gently pull the LCD ribbon out.
