Installing Nikon Coolpix E5700 Top Cover
  1. Installing Nikon Coolpix E5700 Top Cover, Battery: step 1, image 1 of 2 Installing Nikon Coolpix E5700 Top Cover, Battery: step 1, image 2 of 2
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Installing Nikon Coolpix E5700 Top Cover: step 2, image 1 of 1
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Installing Nikon Coolpix E5700 Top Cover, Back Panel: step 3, image 1 of 1
    • Turn to the bottom of the camera.
    • Remove the two Phillips screws located directly below the back monitor
  4. Installing Nikon Coolpix E5700 Top Cover: step 4, image 1 of 2 Installing Nikon Coolpix E5700 Top Cover: step 4, image 2 of 2
    • Turn the camera to the side with the memory card slot and open the compartment for the CF card.
    • Remove the top two Phillips screws closest to the back panel.
  5. Installing Nikon Coolpix E5700 Top Cover: step 5, image 1 of 1
    • Turn to the back of the camera.
    • Remove the top most Phillips screw on the back panel.
  6. Installing Nikon Coolpix E5700 Top Cover: step 6, image 1 of 1
    • Turn to the last side of the back panel.
    • Remove the Phillips screw below the eyepiece.
    • Remove the Phillips screw located above the speaker.
  7. Installing Nikon Coolpix E5700 Top Cover: step 7, image 1 of 2 Installing Nikon Coolpix E5700 Top Cover: step 7, image 2 of 2
    • Gently begin to remove the back panel.
    • Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
  8. Installing Nikon Coolpix E5700 Top Cover: step 8, image 1 of 2 Installing Nikon Coolpix E5700 Top Cover: step 8, image 2 of 2
    • Now gently unplug the two wires at the bottom of the panel.
  9. Installing Nikon Coolpix E5700 Top Cover, Top Cover: step 9, image 1 of 1
    • Finish pulling away the back panel.
    • Turn the camera to its non-grip side.
    • Remove the Phillips screw located above the strap holder.
  10. Installing Nikon Coolpix E5700 Top Cover: step 10, image 1 of 2 Installing Nikon Coolpix E5700 Top Cover: step 10, image 2 of 2
    • Open the CF card slot.
    • Remove the Phillips screw near the top of the camera.
  11. Installing Nikon Coolpix E5700 Top Cover: step 11, image 1 of 1
    • Turn to the front of the camera.
    • Lift up the corner of the grip pad nearest to the flash bulb.
    • Remove the Phillips screw underneath the grip pad.
  12. Installing Nikon Coolpix E5700 Top Cover: step 12, image 1 of 2 Installing Nikon Coolpix E5700 Top Cover: step 12, image 2 of 2
    • Lift up the flash bulb container.
    • Remove the two Phillips screws located near the base of the section.
  13. Installing Nikon Coolpix E5700 Top Cover: step 13, image 1 of 2 Installing Nikon Coolpix E5700 Top Cover: step 13, image 2 of 2
    • Open the battery compartment.
    • Remove the Phillips screw located at the bottom of the battery compartment.
  14. Installing Nikon Coolpix E5700 Top Cover: step 14, image 1 of 1
    • Begin to lift the top cover from the rest of the camera.
    • Be careful when doing this because many wires are connecting the top piece to the camera. Pulling too hard may pull these wires out.
  15. Installing Nikon Coolpix E5700 Top Cover: step 15, image 1 of 1
    • In order to pull the top panel without removing the flash unit. You must remove the flash top cover, taking away the screw under the bulb (see image). then gently remove the plastic top cover. IMPORTANT: discharge the condenser as soon as possible (the flash wires are now exposed, and dangerous ).
  16. Installing Nikon Coolpix E5700 Top Cover: step 16, image 1 of 2 Installing Nikon Coolpix E5700 Top Cover: step 16, image 2 of 2
    • Unplug the orange ribbon wire from the back of the camera.
    • Unplug the blue ribbon wire from the back of the camera.
  17. Installing Nikon Coolpix E5700 Top Cover: step 17, image 1 of 2 Installing Nikon Coolpix E5700 Top Cover: step 17, image 2 of 2
    • Remove the Phillips screws on both sides of the flash bulb mount.
  18. Installing Nikon Coolpix E5700 Top Cover: step 18, image 1 of 2 Installing Nikon Coolpix E5700 Top Cover: step 18, image 2 of 2
    • Lift the top panel up and pull the flash bulb housing away from the rest of the top panel.
    • Note: The top panel will be difficult to separate from the flash bulb housing. Place your hands as shown in the picture and push upward with your thumb while holding the flash bulb housing stationary
  19. Installing Nikon Coolpix E5700 Top Cover: step 19, image 1 of 1
    • Unplug the orange ribbon and the other wires and finish carefully removing the top panel.
Kyle Sitton
351 Reputation
7 Guides authored
Cal Poly, Team 24-58, Amido Spring 2011 Member of Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
4 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,537
