Installing Nikon Coolpix E5700 Back Panel
  1. Installing Nikon Coolpix E5700 Back Panel, Battery: step 1, image 1 of 2 Installing Nikon Coolpix E5700 Back Panel, Battery: step 1, image 2 of 2
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Installing Nikon Coolpix E5700 Back Panel: step 2, image 1 of 1
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Installing Nikon Coolpix E5700 Back Panel, Back Panel: step 3, image 1 of 1
    • Turn to the bottom of the camera.
    • Remove the two Phillips screws located directly below the back monitor
  4. Installing Nikon Coolpix E5700 Back Panel: step 4, image 1 of 2 Installing Nikon Coolpix E5700 Back Panel: step 4, image 2 of 2
    • Turn the camera to the side with the memory card slot and open the compartment for the CF card.
    • Remove the top two Phillips screws closest to the back panel.
  5. Installing Nikon Coolpix E5700 Back Panel: step 5, image 1 of 1
    • Turn to the back of the camera.
    • Remove the top most Phillips screw on the back panel.
  6. Installing Nikon Coolpix E5700 Back Panel: step 6, image 1 of 1
    • Turn to the last side of the back panel.
    • Remove the Phillips screw below the eyepiece.
    • Remove the Phillips screw located above the speaker.
  7. Installing Nikon Coolpix E5700 Back Panel: step 7, image 1 of 2 Installing Nikon Coolpix E5700 Back Panel: step 7, image 2 of 2
    • Gently begin to remove the back panel.
    • Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
  8. Installing Nikon Coolpix E5700 Back Panel: step 8, image 1 of 2 Installing Nikon Coolpix E5700 Back Panel: step 8, image 2 of 2
    • Now gently unplug the two wires at the bottom of the panel.
Raana
78 Reputation
2 Guides authored
Cal Poly, Team 24-58, Amido Spring 2011 Member of Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
4 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 15
All Time: 1,966
