Nikon Coolpix 7900 Back Cover Replacement
  1. Nikon Coolpix 7900 Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Nikon Coolpix 7900 Back Cover Replacement: step 2, image 1 of 1
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. Nikon Coolpix 7900 Back Cover Replacement: step 3, image 1 of 1
    • Remove the two 3.0mm screws on the right side of the camera.
  4. Nikon Coolpix 7900 Back Cover Replacement: step 4, image 1 of 1
    • Carefully open the back cover. Take care as there are connectors still attached.
    • Remove the three screws holding the display to the body, located close to the three corners of the LCD display. The picture is not accurate.
  5. Nikon Coolpix 7900 Back Cover Replacement: step 5, image 1 of 1
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  6. Nikon Coolpix 7900 Back Cover Replacement: step 6, image 1 of 1
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
Kaky Payne
112 Reputation
5 Guides authored
Cal Poly, Team 12-38, Regan Spring 2012 Member of Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Members
10 Guides authored
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 12
All Time: 1,277
