Introduction
If your Nikon Coolpix 3500’s lens is damaged, a replacement is necessary. This guide intends to show how to take out, and replace your lens. If the lens is cracked, be mindful not to hurt yourself on the broken glass.
Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
Remove the battery.
Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
Remove the two 4.5 mm screws that sit next to the battery slot.
Remove the 3 mm screw that sits below the CF card slot.
Remove the 4.5 mm screw that sits above the digital I/O cover.
Remove the two 5 mm screws that sit near the camera strap eyelet.
Remove the camera strap eyelet.
Remove the five 3.5 mm screws that sit at the bottom of the camera.
Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
Using a spudger, detach the white-capped wire.
Using a spudger, detach the orange-capped wire and set the front cover aside.
Disconnect the grey-capped wire from the motherboard.
Disconnect the blue wire attached to the green chip from the center of the motherboard.
Remove the 3.5 mm screw from the logic board next to the rotating lens
Invert the logic board and lens toward the orange and blue wires still connecting the logic board to the LED screen
Disconnect the blue wire connecting the logic board to the LED screen
Disconnect the orange wire using a spudger while pushing out horizontally
Disconnect the red capped wire from the logic board
Lift the logic board and lens (still connected) out of the back case
Lift up on the black covering and remove the orange wire connecting the lens to the logic board
