Nikon CoolPix S600 LCD Replacement
  1. Nikon CoolPix S600 LCD Replacement, Front and Rear Casing: step 1, image 1 of 1
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 LCD Replacement: step 2, image 1 of 1
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 LCD Replacement: step 3, image 1 of 1
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 LCD Replacement: step 4, image 1 of 2 Nikon CoolPix S600 LCD Replacement: step 4, image 2 of 2
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 LCD Replacement: step 5, image 1 of 2 Nikon CoolPix S600 LCD Replacement: step 5, image 2 of 2
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 LCD Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 LCD Replacement: step 7, image 1 of 1
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 LCD Replacement: step 8, image 1 of 2 Nikon CoolPix S600 LCD Replacement: step 8, image 2 of 2
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 LCD Replacement: step 9, image 1 of 1
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 LCD Replacement: step 10, image 1 of 3 Nikon CoolPix S600 LCD Replacement: step 10, image 2 of 3 Nikon CoolPix S600 LCD Replacement: step 10, image 3 of 3
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  11. Nikon CoolPix S600 LCD Replacement, LCD: step 11, image 1 of 1
    • Gently remove LCD ribbon from the mother board
    • The screen will still be connected to the mother board by two very small wires (black & red)
  12. Nikon CoolPix S600 LCD Replacement: step 12, image 1 of 1
    • Desolder both wires from the mother board.
    • Refer to iFixit's solder/desoldering guide for the correct procedure to desolder the connection.
  13. Nikon CoolPix S600 LCD Replacement: step 13, image 1 of 1
    • Separate the LCD screen from the rest of the mother board
andreas anggasastra
116 Reputation
5 Guides authored
Cuesta, Team 1-6, Zipperian Fall 2011 Member of Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
2 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,327
