Installing Nikon COOLPIX S610c Front Casing
  1. Installing Nikon COOLPIX S610c Front Casing, Battery: step 1, image 1 of 1
    • On the bottom right of the camera, locate the battery flap switch.
  2. Installing Nikon COOLPIX S610c Front Casing: step 2, image 1 of 1
    • Move this switch to the right so the battery flap can flip open.
  3. Installing Nikon COOLPIX S610c Front Casing: step 3, image 1 of 1
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Installing Nikon COOLPIX S610c Front Casing, Rear Casing: step 4, image 1 of 1
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Installing Nikon COOLPIX S610c Front Casing: step 5, image 1 of 1
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Installing Nikon COOLPIX S610c Front Casing: step 6, image 1 of 1
    • Pry the panel off from the bottom using your fingernail.
  7. Installing Nikon COOLPIX S610c Front Casing: step 7, image 1 of 1
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Installing Nikon COOLPIX S610c Front Casing: step 8, image 1 of 2 Installing Nikon COOLPIX S610c Front Casing: step 8, image 2 of 2
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Installing Nikon COOLPIX S610c Front Casing: step 9, image 1 of 2 Installing Nikon COOLPIX S610c Front Casing: step 9, image 2 of 2
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Installing Nikon COOLPIX S610c Front Casing: step 10, image 1 of 2 Installing Nikon COOLPIX S610c Front Casing: step 10, image 2 of 2
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
  11. Installing Nikon COOLPIX S610c Front Casing, Front Casing: step 11, image 1 of 1
    • Remove the three 3x3mm screws that attach the front casing to the bottom.
  12. Installing Nikon COOLPIX S610c Front Casing: step 12, image 1 of 1
    • Remove the two 3x2 screws and two 3.5x2.5 screws attaching the rear panel to the motherboard.
  13. Installing Nikon COOLPIX S610c Front Casing: step 13, image 1 of 2 Installing Nikon COOLPIX S610c Front Casing: step 13, image 2 of 2
    • Lift the back panel off the motherboard.
    • Be careful not to damage the ribbon cable that attaches the mother board to the rear panel.
  14. Installing Nikon COOLPIX S610c Front Casing: step 14, image 1 of 2 Installing Nikon COOLPIX S610c Front Casing: step 14, image 2 of 2
    • Detach the ribbon cable from the motherboard by flipping up the latch on the ribbon connector.
    • Note that the white ribbon connector latch flips away from the ribbon cable.
  15. Installing Nikon COOLPIX S610c Front Casing: step 15, image 1 of 2 Installing Nikon COOLPIX S610c Front Casing: step 15, image 2 of 2
    • Remove the final 4x3mm screw at the top of the camera near the lens.
  16. Installing Nikon COOLPIX S610c Front Casing: step 16, image 1 of 2 Installing Nikon COOLPIX S610c Front Casing: step 16, image 2 of 2
    • Pry the front casing away from the body of the camera.
    • Be careful not to damage the wires that attach the front panel to the motherboard.
    • Short the leads on the capacitor near the flash to avoid a nasty shock when separating the casing from the body.
  17. Installing Nikon COOLPIX S610c Front Casing: step 17, image 1 of 1
    • Unscrew the three 3x2mm screws that attach the cables to the front casing.
Bryan Bell
28 Reputation
1 Guide authored
Cal Poly, Team 9-5, Regan Winter 2012 Member of Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,144
