Introduction
This guide showcases how to replace the focusing screen on the Nikon COOLPIX p7700 camera. Follow these 18 steps to ensure proper replacement of the camera's focusing lens.
Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
Remove the side panel.
Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
Once the back casing is off, locate the 4.3 mm silver screw near the top of the camera and remove it using the Phillips #00 screwdriver.
Remove the four 4.3 mm silver screws located on the ends of the chip using the Phillips #00 screwdriver.
Remove the two 4.3 mm silver screws on the far right side of the camera using the Phillips #00 screwdriver.
