Introduction
This guide provides thorough step-by-step instructions that teach a user of the Nikon COOLPIX P600 how to replace the tripod mount.
Use a Phillips screwdriver and remove the eleven 5.556 mm screws around the outside frame of the camera.
Open the "HDMI" rubber flap.
Use a Phillips screwdriver and remove the 5.556 mm screw underneath the flap.
Use needle-nose tweezers to gently lift the black/grey latch towards the ribbon-wire (the latch rotates upward to release and snaps down to lock).
Use tweezers to gently remove ribbon-wires.
Pull the ribbon-wires towards the back-end of the camera.
Use a Phillips screwdriver and remove the single 6.350 mm screw, left of the mode-adjustment dial.
Use needle-nose tweezers to remove the large ribbon-wire located under the screw.
Gently wiggle the ribbon out in an upward motion.
Insert a plastic opening tool under the shutter button.
Gently pry (back and forth) between the rubber grip and camera casing.
Place hands around the camera. Hold onto the mode dial and grip under the shutter button.
Gently push right thumb away and pull in left index finger to separate the camera halves.
Use a Phillips screwdriver to remove the nine 3.175 mm screws on the inside of the camera.
Use tweezers to remove the golden bracket.
Use tweezers to remove the white film under the shutter-release button.
CAUTION: Three high discharge capacitor leads are located under this film. Can result in electric shock if touched.
Use tweezers to remove the yellow ribbon-wire.
Gently wiggle it to the left and then out of it's port.
