The FPC cable is inserted from right side of this photo.
Insert a fine tip tweezer or any thin flat tip tool under the latch, and gentally lift it.
The latch rotates CCW for about 90 degrees
Tool used on this step:Tweezers$4.99
Peel tape with an isolated tool (plastic crowbar, plastic tweezers, toothpick etc). DO NOT USE metal tweezers.
Use a 2-10kohm 5W resistor to discharge flash condenser, for atleast 10 seconds.
Check voltage across 2 points. Make sure it's below 5V DC
Flash solenoid and detect
Microphones and AF assistant LED
Keypad
Switches
NFC
WiFi and Bluetooth, Lens(back)
CMOS sensor
LCD
