Nike SportWatch GPS Unit Replacement
  1. Nike SportWatch GPS Unit Replacement, GPS Unit: step 1, image 1 of 1
    • Using a size #000 Phillips screwdriver, remove the six 5 mm screws on the back of the device.
  2. Nike SportWatch GPS Unit Replacement: step 2, image 1 of 1
    • Then, gently pull the watch band and front screen apart.
  3. Nike SportWatch GPS Unit Replacement: step 3, image 1 of 1
    • Using a size #000 Phillips screwdriver, remove the two 2.5 mm screws on the main board.
  4. Nike SportWatch GPS Unit Replacement: step 4, image 1 of 1
    • Carefully, use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and is not removable.
  5. Nike SportWatch GPS Unit Replacement: step 5, image 1 of 1
    • Use a spudger, to remove the orange tape that covers the wire for the GPS.
  6. Nike SportWatch GPS Unit Replacement: step 6, image 1 of 1
    • Using the soldering iron, break the wire connecting the GPS to the main board at the connector.
    • When you are reassembling the watch, you will have to solder the wire back together.
  7. Nike SportWatch GPS Unit Replacement: step 7, image 1 of 1
    • Use the plastic opening tool to pry out the GPS unit.
Ian Eichorn
678 Reputation
4 Guides authored
3 Comments
which GPS unit is it?
charles - Reply
what gps unit is it?
charles - Reply
I would also like to know what GPS unit that is and if it is possible to find a replacement or a compatible unit?
avs4820 - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 1,888
