Nike SportWatch GPS Battery Replacement
  1. Nike SportWatch GPS Battery Replacement, Battery: step 1, image 1 of 1
    • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Battery Replacement: step 2, image 1 of 1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Battery Replacement: step 3, image 1 of 1
    • Pry the black plastic piece above the battery out using a nylon or metal spudger.
    • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
  4. Nike SportWatch GPS Battery Replacement: step 4, image 1 of 1
    • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
  5. Nike SportWatch GPS Battery Replacement: step 5, image 1 of 1
    • The battery should then easily come out of the watch.
Ian Eichorn
678 Reputation
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 42
All Time: 16,984
