Installing Nexus S Rear Inner Frame
  1. Installing Nexus S Rear Inner Frame, Rear Panel: step 1, image 1 of 1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Installing Nexus S Rear Inner Frame: step 2, image 1 of 1
    • Remove the rear panel from the Nexus S.
  3. Installing Nexus S Rear Inner Frame, Battery: step 3, image 1 of 1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Installing Nexus S Rear Inner Frame, SIM Card: step 4, image 1 of 2 Installing Nexus S Rear Inner Frame, SIM Card: step 4, image 2 of 2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Installing Nexus S Rear Inner Frame, Rear Inner Frame: step 5, image 1 of 1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Installing Nexus S Rear Inner Frame: step 6, image 1 of 1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Installing Nexus S Rear Inner Frame: step 7, image 1 of 2 Installing Nexus S Rear Inner Frame: step 7, image 2 of 2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Installing Nexus S Rear Inner Frame: step 8, image 1 of 2 Installing Nexus S Rear Inner Frame: step 8, image 2 of 2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Installing Nexus S Rear Inner Frame: step 9, image 1 of 1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Installing Nexus S Rear Inner Frame: step 10, image 1 of 1
    • Lift and remove the rear inner frame from the Nexus S.
  11. Installing Nexus S Rear Inner Frame, Rear Inner Frame: step 11, image 1 of 1
    • Rear inner frame remains.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 6
All Time: 3,019
