Installing Nexus S Rear Inner Frame
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing Nexus S Rear Inner Frame, Rear Inner Frame: step 1, image 1 of 1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  2. Installing Nexus S Rear Inner Frame: step 2, image 1 of 1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  3. Installing Nexus S Rear Inner Frame: step 3, image 1 of 2 Installing Nexus S Rear Inner Frame: step 3, image 2 of 2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  4. Installing Nexus S Rear Inner Frame: step 4, image 1 of 2 Installing Nexus S Rear Inner Frame: step 4, image 2 of 2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  5. Installing Nexus S Rear Inner Frame: step 5, image 1 of 1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  6. Installing Nexus S Rear Inner Frame: step 6, image 1 of 1
    • Lift and remove the rear inner frame from the Nexus S.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 303
