Installing Nexus One Flash
  1. Installing Nexus One Flash, Rear Cover: step 1, image 1 of 2 Installing Nexus One Flash, Rear Cover: step 1, image 2 of 2
    • Using two fingers, push up on the rear cover.
  2. Installing Nexus One Flash: step 2, image 1 of 1
    • The rear cover slides up and off.
  3. Installing Nexus One Flash, Battery: step 3, image 1 of 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Installing Nexus One Flash: step 4, image 1 of 1
    • Pull the battery up and out.
  5. Installing Nexus One Flash, Battery Housing: step 5, image 1 of 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Installing Nexus One Flash: step 6, image 1 of 2 Installing Nexus One Flash: step 6, image 2 of 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Installing Nexus One Flash: step 7, image 1 of 2 Installing Nexus One Flash: step 7, image 2 of 2
    • Pry the upper left tab open on the battery housing.
  8. Installing Nexus One Flash: step 8, image 1 of 2 Installing Nexus One Flash: step 8, image 2 of 2
    • Pry the top tab of the battery housing.
  9. Installing Nexus One Flash: step 9, image 1 of 2 Installing Nexus One Flash: step 9, image 2 of 2
    • Pry the right side tab of the battery housing.
  10. Installing Nexus One Flash: step 10, image 1 of 2 Installing Nexus One Flash: step 10, image 2 of 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Installing Nexus One Flash, Flash: step 11, image 1 of 1
    • Insert the spudger under the bottom of the flash board
    • Twist the spudger to lift and release the flash board.
Niklas Johnson
1,207 Reputation
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,835
