Nexus 7 2nd Generation Battery Replacement
  1. Nexus 7 2nd Generation Battery Replacement, Back Cover: step 1, image 1 of 2 Nexus 7 2nd Generation Battery Replacement, Back Cover: step 1, image 2 of 2
    • Power down your device.
    • Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time. For some a finger nail may be best. The case comes up quite high to the glass.
    • Do not pry near the USB port at the base of the device as you may crack the rear panel.
  2. Nexus 7 2nd Generation Battery Replacement: step 2, image 1 of 1
    • Work fingers around the seam between device and back cover. Use your plastic opening tool and fingers to separate each side until device and back cover are completely apart.
    • Be careful around the corners. The body of the device can be fragile.
  3. Nexus 7 2nd Generation Battery Replacement, Battery: step 3, image 1 of 1
    • Insert the plastic opening tool under the side edge of the battery connector, and gently pry upward to disconnect it.
  4. Nexus 7 2nd Generation Battery Replacement: step 4, image 1 of 3 Nexus 7 2nd Generation Battery Replacement: step 4, image 2 of 3 Nexus 7 2nd Generation Battery Replacement: step 4, image 3 of 3
    • Use the flat end of a spudger or your fingernail to flip up the clear protective flap on the ribbon cable ZIF socket.
    • Using the flat end of a spudger or your fingernail, flip up the thin portion of the connector (opposite of the side where the cable inserts) to release the cable from its socket.
    • DO NOT PRY the socket on the side where the cable inserts, or you may break the entire socket off the motherboard.
    • Slide the cable out of the ZIF socket.
    • For more info on how to disconnect ZIF connectors, check out the Recognizing & Disconnecting Cable Connectors guide.
  5. Nexus 7 2nd Generation Battery Replacement: step 5, image 1 of 1
    • Peel protective foil cover back top of mother board to expose orange ribbon connection.
    • The ribbon connections should now be fully visible, with the plastic tabs exposed.
  6. Nexus 7 2nd Generation Battery Replacement: step 6, image 1 of 3 Nexus 7 2nd Generation Battery Replacement: step 6, image 2 of 3 Nexus 7 2nd Generation Battery Replacement: step 6, image 3 of 3
    • Using the tweezers, peel back the silver protective foil on top of the orange ribbon connector.
    • Using the plastic opening tool, pry upward under the orange ribbon connector. It will pop right out of place.
  7. Nexus 7 2nd Generation Battery Replacement: step 7, image 1 of 2 Nexus 7 2nd Generation Battery Replacement: step 7, image 2 of 2
    • Now that the two main ribbons are disconnected, fold and hold them back with your fingers, or place the tweezers or a light object on the ribbons to keep them in place.
  8. Nexus 7 2nd Generation Battery Replacement: step 8, image 1 of 1
    • Use the #0 Phillips Screwdriver to remove the four silver 3 mm Philips #0 screws from around the battery housing.
  9. Nexus 7 2nd Generation Battery Replacement: step 9, image 1 of 1
    • Remove the battery from your device by applying pressure at the base of the battery and lifting it out.
Heather
1,419 Reputation
2 Guides authored
Cal Poly, Team 20-16, Maness Winter 2015 Member of Cal Poly, Team 20-16, Maness Winter 2015
CPSU-MANESS-W15S20G16
4 Members
24 Guides authored
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 213
All Time: 43,611
