Nexus 6P Daughterboard/Charging Port Replacement
Video Overview
  1. Nexus 6P Daughterboard/Charging Port Replacement: step 2, image 1 of 3 Nexus 6P Daughterboard/Charging Port Replacement: step 2, image 2 of 3 Nexus 6P Daughterboard/Charging Port Replacement: step 2, image 3 of 3
    • Heat up back glass panel.
    • Use hobby knife to open a gap and cut the fierce sticker underneath rear glass panel.
    • The back glass panel is easily shattered and the adhesive underneath is fierce. So be careful to pry this part.
  2. Nexus 6P Daughterboard/Charging Port Replacement: step 3, image 1 of 3 Nexus 6P Daughterboard/Charging Port Replacement: step 3, image 2 of 3 Nexus 6P Daughterboard/Charging Port Replacement: step 3, image 3 of 3
    • Heat up bottom plastic panel.
    • Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath.
  3. Nexus 6P Daughterboard/Charging Port Replacement: step 4, image 1 of 3 Nexus 6P Daughterboard/Charging Port Replacement: step 4, image 2 of 3 Nexus 6P Daughterboard/Charging Port Replacement: step 4, image 3 of 3
    • Twist off 6 Phillips screws together.
    • Insert guitar picks and plastic opening tool to separate front assembly from back cover.
    • Attention: These two parts fit tightly.It is the toughest part to separate. You can also try using heavy-duty suction cup to disassemble them.
  4. Nexus 6P Daughterboard/Charging Port Replacement: step 5, image 1 of 3 Nexus 6P Daughterboard/Charging Port Replacement: step 5, image 2 of 3 Nexus 6P Daughterboard/Charging Port Replacement: step 5, image 3 of 3
    • Unscrew one Phillips screw.
    • Remove metal bracket securing flex contactors.
    • Release 3 flex contactors and remove it .
    • This flex is used to connect motherboard and daughterboard.
  5. Nexus 6P Daughterboard/Charging Port Replacement: step 6, image 1 of 3 Nexus 6P Daughterboard/Charging Port Replacement: step 6, image 2 of 3 Nexus 6P Daughterboard/Charging Port Replacement: step 6, image 3 of 3
    • Disconnect signal cable contactor and twist off one Phillips screw.
    • Remove daughterboard.
  6. Nexus 6P Daughterboard/Charging Port Replacement: step 7, image 1 of 1
    • Here is the daughtrboard. The charing port is attached here.
Witrigs
69,496 Reputation
378 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 18,219
