How to Repair Water Damaged Nexus 5x
  1. How to Repair Water Damaged Nexus 5x, Rear Panel: step 1, image 1 of 3 How to Repair Water Damaged Nexus 5x, Rear Panel: step 1, image 2 of 3 How to Repair Water Damaged Nexus 5x, Rear Panel: step 1, image 3 of 3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  2. How to Repair Water Damaged Nexus 5x: step 2, image 1 of 3 How to Repair Water Damaged Nexus 5x: step 2, image 2 of 3 How to Repair Water Damaged Nexus 5x: step 2, image 3 of 3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  3. How to Repair Water Damaged Nexus 5x: step 3, image 1 of 2 How to Repair Water Damaged Nexus 5x: step 3, image 2 of 2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
  4. How to Repair Water Damaged Nexus 5x, Midframe: step 4, image 1 of 1
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
  5. How to Repair Water Damaged Nexus 5x: step 5, image 1 of 2 How to Repair Water Damaged Nexus 5x: step 5, image 2 of 2
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
  6. How to Repair Water Damaged Nexus 5x: step 6, image 1 of 2 How to Repair Water Damaged Nexus 5x: step 6, image 2 of 2
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
  7. How to Repair Water Damaged Nexus 5x: step 7, image 1 of 2 How to Repair Water Damaged Nexus 5x: step 7, image 2 of 2
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
  8. How to Repair Water Damaged Nexus 5x: step 8, image 1 of 2 How to Repair Water Damaged Nexus 5x: step 8, image 2 of 2
    • Make sure all the clips are free.
    • Carefully remove the midframe.
  9. How to Repair Water Damaged Nexus 5x, Motherboard: step 9, image 1 of 3 How to Repair Water Damaged Nexus 5x, Motherboard: step 9, image 2 of 3 How to Repair Water Damaged Nexus 5x, Motherboard: step 9, image 3 of 3
    • Proceed with the following steps if you need to transfer the front-facing and rear-facing cameras to the new motherboard.
    • Use the flat end of a spudger to pry up the rear-facing camera connector from the motherboard.
    • Carefully remove the rear facing camera.
  10. How to Repair Water Damaged Nexus 5x: step 10, image 1 of 3 How to Repair Water Damaged Nexus 5x: step 10, image 2 of 3 How to Repair Water Damaged Nexus 5x: step 10, image 3 of 3
    • Use the flat end of a spudger to pry up the front-facing camera connector from the motherboard.
    • Carefully remove the front-facing camera.
  11. How to Repair Water Damaged Nexus 5x, How to Repair Water Damaged Nexus 5x: step 11, image 1 of 1
    • ESD or Electro-Static Discharge can damage sensitive circuitry so do not touch anything on circuit board, such as connectors and resistors, with your bare hands!
    • This process may not work if you attempted to turn on /charge your device after it was exposed to water.
    • Hardware damage is always a possibility, so this process is only to give your device the best chance of survival.
    • After completing the preliminary teardown task you will need to carefully remove metal covers on front and back of the motherboard with your knife.
    • They simply unclip and clip back in.
  12. How to Repair Water Damaged Nexus 5x: step 12, image 1 of 2 How to Repair Water Damaged Nexus 5x: step 12, image 2 of 2
    • Clean entire board with your Alcohol, making sure all water has been cleaned and all corrosion is gone after alcohol dries.
    • Alcohol MUST be 90% or higher
    • Continue cleaning any water within device as well as all connectors.
  13. How to Repair Water Damaged Nexus 5x: step 13, image 1 of 1
    • Do not exeed temp greater than 150F to avoid damage to hardware
    • Take the screen portion only and place it in your oven/toaster oven that can stay at a constant 140-150F for 2hrs. This will evaporate any water behind the screen that you cannot reach with your alcohol.
  14. How to Repair Water Damaged Nexus 5x: step 14, image 1 of 1
    • Re-assemble and power on!
9 other people completed this guide.
Allen Finley
390 Reputation
1 Guide authored
9 Comments
Where is the microphone located at? Mine was water damaged and it works fine except for the microphone is very low. Thanks in advance for your help
John Zenobia - Reply
If you look at the bottom of your Nexus 5x you will see a pin hole that allows the microphone to receive your voice. The microphone component will be right above that small hole. Unfortunately, I believe that the microphone component itself is soldered to the motherboard. You may be able to clean it more with alcohol and try again after it dries. Buying a new microphone and soldering on the new one would require a special soldering iron and almost expert skill. If you could purchase one with a broken screen for a reasonable price you could replace your whole motherboard with ease
Allen Finley -
My nexus 5x was water damaged about 3 months ago.If follow this process ,is it possible to recover it?
Talha Babor - Reply
Did you tried it? I want to give it a go, if it’s still possible, but its broken about half a year.
Balázs Bulcsú -
My phone is not working it was fine till morning phone automatically switched off tried 1000 times its not working.
Amritpal Singh - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 15
All Time: 12,840
