Introduction
Use this guide to replace the battery of your Nexus 5.
Use a plastic opening tool to free the clips on the top and each side of the back cover.
Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
Tool used on this step:Spudger$2.99
Use the flat end of a nylon spudger to disconnect the battery connector.
Use the flat end of a spudger to disconnect the daughterboard ribbon cable and pull it away from the battery.
Use a plastic opening tool to pry the battery out of its housing.
If replacing the battery, bag the old battery up and recycle responsibly at a suitable location.
