Nextbook 8 Screen Replacement
  1. Nextbook 8 Screen Replacement, Battery: step 1, image 1 of 2 Nextbook 8 Screen Replacement, Battery: step 1, image 2 of 2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Screen Replacement: step 2, image 1 of 2 Nextbook 8 Screen Replacement: step 2, image 2 of 2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Screen Replacement: step 3, image 1 of 2 Nextbook 8 Screen Replacement: step 3, image 2 of 2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Screen Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Screen Replacement: step 5, image 1 of 2 Nextbook 8 Screen Replacement: step 5, image 2 of 2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
  6. Nextbook 8 Screen Replacement, Screen: step 6, image 1 of 1
    • Remove the silver and gold sticker at the bottom of the device.
    • Hold the brown circuit board down with your finger while you remove the sticker
  7. Nextbook 8 Screen Replacement: step 7, image 1 of 2 Nextbook 8 Screen Replacement: step 7, image 2 of 2
    • Use a spudger to lift up the black tabs on the three ZIF connectors.
    • Use ESD safe tweezers to pull the white and blue ribbon cables out of the connectors.
  8. Nextbook 8 Screen Replacement: step 8, image 1 of 2 Nextbook 8 Screen Replacement: step 8, image 2 of 2
    • Remove the 5 black screws in the motherboard to remove it from the device.
    • Carefully lift the motherboard off of the device and set it aside for now.
  9. Nextbook 8 Screen Replacement: step 9, image 1 of 2 Nextbook 8 Screen Replacement: step 9, image 2 of 2
    • Remove the two screws that hold the brackets in place.
    • Remove the two silver brackets that hold the screen in place.
  10. Nextbook 8 Screen Replacement: step 10, image 1 of 2 Nextbook 8 Screen Replacement: step 10, image 2 of 2
    • Remove the one silver screw on the small green circuit board at the bottom of the device.
    • Set aside the small circuit board for now.
  11. Nextbook 8 Screen Replacement: step 11, image 1 of 1
    • Remove the two silver screws from the bottom of the device.
  12. Nextbook 8 Screen Replacement: step 12, image 1 of 3 Nextbook 8 Screen Replacement: step 12, image 2 of 3 Nextbook 8 Screen Replacement: step 12, image 3 of 3
    • With the device face down, use a spudger to lift the screen off of the glass from the right side.
Dylan Wiese
1,853 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 23,875
