Nextbook 8 Battery Replacement
  1. Nextbook 8 Battery Replacement, Battery: step 1, image 1 of 2 Nextbook 8 Battery Replacement, Battery: step 1, image 2 of 2
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Battery Replacement: step 2, image 1 of 2 Nextbook 8 Battery Replacement: step 2, image 2 of 2
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Battery Replacement: step 3, image 1 of 2 Nextbook 8 Battery Replacement: step 3, image 2 of 2
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Battery Replacement: step 4, image 1 of 1
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Battery Replacement: step 5, image 1 of 2 Nextbook 8 Battery Replacement: step 5, image 2 of 2
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
Dylan Wiese
1,853 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 31
All Time: 42,174
