NexiGo NS32 Vibration Motor Replacement
  1. NexiGo NS32 Vibration Motor Replacement, Rear Case: step 1, image 1 of 1
    • Orient the controller so that it is face down.
  2. NexiGo NS32 Vibration Motor Replacement: step 2, image 1 of 2 NexiGo NS32 Vibration Motor Replacement: step 2, image 2 of 2
    • Remove the eight 9 mm Phillips screws that secure the rear case.
  3. NexiGo NS32 Vibration Motor Replacement: step 3, image 1 of 1
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
  4. NexiGo NS32 Vibration Motor Replacement, Vibration Motor: step 4, image 1 of 3 NexiGo NS32 Vibration Motor Replacement, Vibration Motor: step 4, image 2 of 3 NexiGo NS32 Vibration Motor Replacement, Vibration Motor: step 4, image 3 of 3
    • Grip the white vibration motor connections and pull them directly out of their sockets.
  5. NexiGo NS32 Vibration Motor Replacement: step 5, image 1 of 2 NexiGo NS32 Vibration Motor Replacement: step 5, image 2 of 2
    • Gently lift out the vibration motors.
    • The vibration motors may be glued in place. If you're having trouble removing them, apply some high-concentration isopropyl alcohol to loosen the adhesive.
Naiza Hall
265 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 137
