NexiGo NS32 Battery Replacement
    1. NexiGo NS32 Battery Replacement, Rear Case: step 1, image 1 of 1
      • Orient the controller so that it is face down.
      Ask FixBot
    2. NexiGo NS32 Battery Replacement: step 2, image 1 of 2 NexiGo NS32 Battery Replacement: step 2, image 2 of 2
      • Remove the eight 9 mm Phillips screws that secure the rear case.
      Ask FixBot
    3. NexiGo NS32 Battery Replacement: step 3, image 1 of 1
      • Lift the rear case up and off.
      • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
      Ask FixBot
    1. NexiGo NS32 Battery Replacement, Battery: step 4, image 1 of 2 NexiGo NS32 Battery Replacement, Battery: step 4, image 2 of 2
      • Grip the white battery connector and pull it directly out of its motherboard socket.
      • This may require some force, as the connectors are secured with a bit of adhesive. If you're having trouble with disconnection, apply some high-concentration isopropyl alcohol to the adhesive to loosen it.
      • Do not pull on the wires.
      Ask FixBot
    2. NexiGo NS32 Battery Replacement: step 5, image 1 of 3 NexiGo NS32 Battery Replacement: step 5, image 2 of 3 NexiGo NS32 Battery Replacement: step 5, image 3 of 3
      • Lift the battery up and out.
      • Take care not to bend or puncture the battery as you remove it.
      Ask FixBot
1 Guide Comment
Do you know what model battery I would need to buy to replace the original?
Jack Dunne - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 434
