This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Network/Wi-Fi Card
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
74
All Time:
407
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Community-Contributed Guide
Network/Wi-Fi Card
Introduction
Go to step 1 ↓
This guide shows you how to remove the Wi-Fi card from an NH57ADS, once the lower case and battery have been removed.
    1. Network/Wi-Fi Card, Battery: step 1, image 1 of 3 Network/Wi-Fi Card, Battery: step 1, image 2 of 3 Network/Wi-Fi Card, Battery: step 1, image 3 of 3
      • Remove the two screws holding the battery in place.
      • Slip your finger into the finger hole provided at the top of the battery.
      • ...and lift to remove it
      Ask FixBot
    1. Network/Wi-Fi Card, Bottom Cover: step 2, image 1 of 3 Network/Wi-Fi Card, Bottom Cover: step 2, image 2 of 3 Network/Wi-Fi Card, Bottom Cover: step 2, image 3 of 3
      • Remove the five Phillips screws securing the bottom to the case.
      • Slide the cover up slightly to release the clips holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
      Ask FixBot
    2. Network/Wi-Fi Card, Removing the Bottom Cover: step 3, image 1 of 3 Network/Wi-Fi Card, Removing the Bottom Cover: step 3, image 2 of 3 Network/Wi-Fi Card, Removing the Bottom Cover: step 3, image 3 of 3
      • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
      • Slide the bottom cover to remove it.
      Ask FixBot
    1. Network/Wi-Fi Card, The WLAN Card: step 4, image 1 of 2 Network/Wi-Fi Card, The WLAN Card: step 4, image 2 of 2
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Remove the piece of tape and the two cables.
      • Be careful, the 2 cables are very fragile; you can use a Spudger to do it gently.
      • Unscrew and remove the card.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 74
All Time: 407
