Nespresso Vertuo Next Upper Water Line Replacement
  1. Nespresso Vertuo Next Upper Water Line Replacement, Power Button: step 1, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement, Power Button: step 1, image 2 of 2
    • Side an opening tool in between where the top cover meets the white head piece and apply force to push the cover off.
    • Remove the cover from the device.
  2. Nespresso Vertuo Next Upper Water Line Replacement: step 2, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement: step 2, image 2 of 2
    • Use a T19 Torx screwdriver to remove the white top cover of the machine.
    • While pulling away the top cover, ensure that you don't pull out any wires or other parts.
  3. Nespresso Vertuo Next Upper Water Line Replacement: step 3, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement: step 3, image 2 of 2
    • Pop out the power button by pressing your thumb on the button and pressing down.
  4. Nespresso Vertuo Next Upper Water Line Replacement: step 4, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement: step 4, image 2 of 2
    • Use tweezers to unplug the wires from the power button.
    • Apply slight force and carefully pull the wire out as to not damage any pins.
  5. Nespresso Vertuo Next Upper Water Line Replacement, Upper Water Line: step 5, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement, Upper Water Line: step 5, image 2 of 2
    • Use tweezers to remove the clip at the end of the upper water line.
    • Note: You may have to grasp with your other hand and pull the line with your other in order to remove the clip.
  6. Nespresso Vertuo Next Upper Water Line Replacement: step 6, image 1 of 2 Nespresso Vertuo Next Upper Water Line Replacement: step 6, image 2 of 2
    • For the second clip on the lower part of the line, repeat the previous step. After the removal of the second clip, the remove the line.
Tyler Nunes
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 90
All Time: 495
