Nespresso Vertuo Next Lower Water Line Replacement
  1. Nespresso Vertuo Next Lower Water Line Replacement, Water Pump: step 1, image 1 of 3 Nespresso Vertuo Next Lower Water Line Replacement, Water Pump: step 1, image 2 of 3 Nespresso Vertuo Next Lower Water Line Replacement, Water Pump: step 1, image 3 of 3
    • Insert an opening tool in the seams between the rear panel and chassis.
    • Pry off the rear panel.
    • You may need multiple opening tools at once in order to open the device panel.
    Ask FixBot
  2. Nespresso Vertuo Next Lower Water Line Replacement: step 2, image 1 of 3 Nespresso Vertuo Next Lower Water Line Replacement: step 2, image 2 of 3 Nespresso Vertuo Next Lower Water Line Replacement: step 2, image 3 of 3
    • Remove the four 13.5 mm screws on the base plate using a T18 Torx screwdriver.
    Ask FixBot
  3. Nespresso Vertuo Next Lower Water Line Replacement: step 3, image 1 of 3 Nespresso Vertuo Next Lower Water Line Replacement: step 3, image 2 of 3 Nespresso Vertuo Next Lower Water Line Replacement: step 3, image 3 of 3
    • With tweezers, pinch one half of each connected pair of wires, and then gently pull and disconnect the wires.
    • Use a pair of tweezers to clamp down and disconnect the water line connecting to the base plate of the machine.
    • Remove the base plate from device
    • Wires can be fragile, handle with care.
    Ask FixBot
  4. Nespresso Vertuo Next Lower Water Line Replacement: step 4, image 1 of 3 Nespresso Vertuo Next Lower Water Line Replacement: step 4, image 2 of 3 Nespresso Vertuo Next Lower Water Line Replacement: step 4, image 3 of 3
    • Remove the rubber hoop connecting the motor to the base.
    • Lift the motor off of baseplate and pull waterline away from the base.
    Ask FixBot
  5. Nespresso Vertuo Next Lower Water Line Replacement, Lower Water Line: step 5, image 1 of 3 Nespresso Vertuo Next Lower Water Line Replacement, Lower Water Line: step 5, image 2 of 3 Nespresso Vertuo Next Lower Water Line Replacement, Lower Water Line: step 5, image 3 of 3
    • Remove the waterline from the clear water hub by pulling on the end of the line that connects to the main hub at the base.
    • Ensure that you pull tightly on the line in order to remove it
    Ask FixBot
Philip_S
431 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 80
All Time: 824
