Nerf Vortex Praxis Projecting Ejector Clip Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Nerf Vortex Praxis Projecting Ejector Clip Replacement, Projecting Ejector Clip: step 1, image 1 of 1
      • Start by taking out all of the screws for the casing of the gun. Using the PH #00 screwdriver, unscrew all four 1.3-cm screws in the pump.
      Ask FixBot
    2. Nerf Vortex Praxis Projecting Ejector Clip Replacement: step 2, image 1 of 1
      • Take out all of the screws with a Phillips screwdriver. Using a PH #00 Screwdriver, unscrew all fourteen, 1.2-cm screws.
      Ask FixBot
    3. Nerf Vortex Praxis Projecting Ejector Clip Replacement: step 3, image 1 of 1
      • Remove the small stock at the back end of the gun by removing two, 1-cm screws.
      Ask FixBot
    4. Nerf Vortex Praxis Projecting Ejector Clip Replacement: step 4, image 1 of 1
      • Pull apart the case of the gun.
      Ask FixBot
    5. Nerf Vortex Praxis Projecting Ejector Clip Replacement: step 5, image 1 of 1
      • Remove the 1.2 cm Phillips screw and the silver 1.1 cm Phillips screw at the front of the gun.
      • Remove the silver 1.1 cm Phillips screw next to the first screw.
      Ask FixBot
    6. Nerf Vortex Praxis Projecting Ejector Clip Replacement: step 6, image 1 of 1
      • Remove the two 0.7 cm screws that are towards the back of the case.
      Ask FixBot
    7. Nerf Vortex Praxis Projecting Ejector Clip Replacement: step 7, image 1 of 1
      • Pull out the white piece which is the ejector component of the rifle.
      Ask FixBot
Diego medina
558 Reputation
5 Guides authored
IUPUI, Team 3-1, Harley Spring 2016 Member of IUPUI, Team 3-1, Harley Spring 2016
IUPUI-HARLEY-S16S3G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 519
