Nerf N-Strike Maverick Catch Spring Replacement
  1. Nerf N-Strike Maverick Catch Spring Replacement, Use the Teardown Guide to Open the Gun: step 1, image 1 of 1
  2. Nerf N-Strike Maverick Catch Spring Replacement, Remove Large Spring: step 2, image 1 of 1
    • Remove the larger spring from the catch mechanism.
  3. Nerf N-Strike Maverick Catch Spring Replacement, Remove the Catch Mechanism & Spring: step 3, image 1 of 1
    • Remove the catch mechanism and spring by gently lifting it straight up and off the metal pin that holds it.
    • The catch spring has a tendency to bounce away when removed.
  4. Nerf N-Strike Maverick Catch Spring Replacement, Replace the Catch Spring: step 4, image 1 of 1
    • After removing the old catch spring, place the new catch spring back on the tip of the catch mechanism.
    • If you are unable to find an exact replacement, one may be fashioned out of a pen spring.
  5. Nerf N-Strike Maverick Catch Spring Replacement, Putting the Catch Mechanism Back: step 5, image 1 of 1
    • Carefully replace the catch mechanism so that it is seated in the grooves and over the metal pin.
Michael Walker
193 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 7,362
