Neo3Do Battery & LED screen Replacement
  1. Neo3Do Battery & LED screen Replacement, Back Panel: step 1, image 1 of 3 Neo3Do Battery & LED screen Replacement, Back Panel: step 1, image 2 of 3 Neo3Do Battery & LED screen Replacement, Back Panel: step 1, image 3 of 3
    • Turn the Neo3DO face down so that the logo is facing toward you.
    • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
  2. Neo3Do Battery & LED screen Replacement: step 2, image 1 of 2 Neo3Do Battery & LED screen Replacement: step 2, image 2 of 2
    • Gently pry the back panel upwards.
    • Ensure the tool does not slip into the device and damage the internals.
  3. Neo3Do Battery & LED screen Replacement: step 3, image 1 of 2 Neo3Do Battery & LED screen Replacement: step 3, image 2 of 2
    • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
  4. Neo3Do Battery & LED screen Replacement: step 4, image 1 of 1
    • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
    • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
  5. Neo3Do Battery & LED screen Replacement, Motherboard: step 5, image 1 of 3 Neo3Do Battery & LED screen Replacement, Motherboard: step 5, image 2 of 3 Neo3Do Battery & LED screen Replacement, Motherboard: step 5, image 3 of 3
    • Remove all the tape attached to the motherboard.
  6. Neo3Do Battery & LED screen Replacement: step 6, image 1 of 3 Neo3Do Battery & LED screen Replacement: step 6, image 2 of 3 Neo3Do Battery & LED screen Replacement: step 6, image 3 of 3
    • Pull out the black tabs using the plastic spudger.
    • All sockets that require the same step are marked in the first photo.
  7. Neo3Do Battery & LED screen Replacement: step 7, image 1 of 2 Neo3Do Battery & LED screen Replacement: step 7, image 2 of 2
    • Remove the wire belt from the socket.
  8. Neo3Do Battery & LED screen Replacement: step 8, image 1 of 3 Neo3Do Battery & LED screen Replacement: step 8, image 2 of 3 Neo3Do Battery & LED screen Replacement: step 8, image 3 of 3
    • Lift the black tab and then remove the wire belt.
  9. Neo3Do Battery & LED screen Replacement: step 9, image 1 of 3 Neo3Do Battery & LED screen Replacement: step 9, image 2 of 3 Neo3Do Battery & LED screen Replacement: step 9, image 3 of 3
  10. Neo3Do Battery & LED screen Replacement: step 10, image 1 of 3 Neo3Do Battery & LED screen Replacement: step 10, image 2 of 3 Neo3Do Battery & LED screen Replacement: step 10, image 3 of 3
    • Grip the side of the tab and pull upwards to remove it from the socket.
    • Gripping the wire belt and pulling upwards may cause damage, be sure to avoid it.
  11. Neo3Do Battery & LED screen Replacement: step 11, image 1 of 2 Neo3Do Battery & LED screen Replacement: step 11, image 2 of 2
    • Remove the screws using the J0 head screwdriver.
    • All screws that require the same step are marked in the first photo.
  12. Neo3Do Battery & LED screen Replacement: step 12, image 1 of 3 Neo3Do Battery & LED screen Replacement: step 12, image 2 of 3 Neo3Do Battery & LED screen Replacement: step 12, image 3 of 3
    • Grip the active(red) wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
    • Repeat the same process to remove the neutral(black) wire.
    • All wires that require the same steps are marked in the first photo.
    • The soldering tool is extremely hot, use with caution.
  13. Neo3Do Battery & LED screen Replacement: step 13, image 1 of 3 Neo3Do Battery & LED screen Replacement: step 13, image 2 of 3 Neo3Do Battery & LED screen Replacement: step 13, image 3 of 3
    • Use the flat end of the plastic spudger to remove the motherboard and turn it underside-up.
  14. Neo3Do Battery & LED screen Replacement: step 14, image 1 of 2 Neo3Do Battery & LED screen Replacement: step 14, image 2 of 2
    • Remove the plug from the motherboard socket.
  15. Neo3Do Battery & LED screen Replacement: step 15, image 1 of 3 Neo3Do Battery & LED screen Replacement: step 15, image 2 of 3 Neo3Do Battery & LED screen Replacement: step 15, image 3 of 3
    • Grip the wire and apply the soldering tool until the solder is soft enough for the wire to be removed.
  16. Neo3Do Battery & LED screen Replacement, Battery & LED screen: step 16, image 1 of 2 Neo3Do Battery & LED screen Replacement, Battery & LED screen: step 16, image 2 of 2
    • Remove the screws with a J000 screwdriver
  17. Neo3Do Battery & LED screen Replacement: step 17, image 1 of 2 Neo3Do Battery & LED screen Replacement: step 17, image 2 of 2
    • Use the plastic removal tool to remove the plastic frame.
  18. Neo3Do Battery & LED screen Replacement: step 18, image 1 of 3 Neo3Do Battery & LED screen Replacement: step 18, image 2 of 3 Neo3Do Battery & LED screen Replacement: step 18, image 3 of 3
    • Using the plastic removal tool, lift the LED screen from the battery side, and use the tweezers to help lift the LED screen upwards.
Daniel Evans
431 Reputation
4 Guides authored
USF Tampa, Team 14-3, Eyestone Fall 2016 Member of USF Tampa, Team 14-3, Eyestone Fall 2016
USFT-EYESTONE-F16S14G3
3 Members
12 Guides authored
One Comment
Do you have a source for Neo3DO Digitizer replacement.
Chris - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 186
