Nabi Jr Screen Replacement
  1. Nabi Jr Screen Replacement, Rear Case: step 1, image 1 of 1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Screen Replacement: step 2, image 1 of 1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Screen Replacement: step 3, image 1 of 1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Screen Replacement: step 4, image 1 of 1
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Screen Replacement, Motherboard: step 5, image 1 of 1
    • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
  6. Nabi Jr Screen Replacement: step 6, image 1 of 1
    • De-solder the grey wire from motherboard
  7. Nabi Jr Screen Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to peel off all yellow tape from the motherboard
    • Yellow tape is used in all locations where there is ribbon cable present.
  8. Nabi Jr Screen Replacement: step 8, image 1 of 2 Nabi Jr Screen Replacement: step 8, image 2 of 2
    • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
    • Pull black locking tabs up in opposite direction of ribbon cable to remove.
    • Use tweezers to pull the ribbon cable out of the locking tab's slot
  9. Nabi Jr Screen Replacement: step 9, image 1 of 2 Nabi Jr Screen Replacement: step 9, image 2 of 2
    • Lift motherboard to separate it the from the case shell.
  10. Nabi Jr Screen Replacement, Screen: step 10, image 1 of 1
    • Remove the 6 screws that hold the screen in place
  11. Nabi Jr Screen Replacement: step 11, image 1 of 2 Nabi Jr Screen Replacement: step 11, image 2 of 2
    • Remove the screen from the front casing
  12. Nabi Jr Screen Replacement: step 12, image 1 of 1
    • Separate the screen from the plastic casing.
  13. Nabi Jr Screen Replacement: step 13, image 1 of 1
    • Replace the old screen with the new screen
Jimmy Nguyen
271 Reputation
2 Guides authored
3 Comments
Do you know of anywhere I can send a nabi jr to have a cracked screen replaced?
Katie - Reply
Yes thank you for the information but where do we find a screen to replace this?
davemel - Reply
My navi jr is the nick jr edition and looks a bit different inside. I replaced the screen, as mentioned here but has to remove the outter glass-like screen that has the second smaller ribbonattach from the original screen, and put it on my screen because the new screen did not have that part. All buttons work, the screen looks perfect and vibrant, but the EFEN TOUCH Does not work!!! What did I do wrong? I attached all the ribbons properly!!!
vane.lpz - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 5,503
