Introduction
Prerequisite-Only
Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
Repeat for the other three openings.
Locate the white port that connects the back panel to the circuit board on the back of the display.
Carefully pull the plastic connector straight out.
Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
Apply a downward force to carefully peel the grey plastic off of the metal display.
Locate the two cables running on both sides of the device found at the bottom side of the screen.
Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
