NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown
    1. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Get Item and tools in area for dismantle: step 1, image 1 of 3 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Get Item and tools in area for dismantle: step 1, image 2 of 3 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Get Item and tools in area for dismantle: step 1, image 3 of 3
      • Suggested Items Listed
      Ask FixBot
    2. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Top Cover: step 2, image 1 of 2 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Top Cover: step 2, image 2 of 2
      • From here you will want to use the Jimmy or similar item to get under the bottom corner to get past the inner clips. From here you can carefully get both sides of the bottom top cover and lift it off. The remainder of the cover should come off fairly easily. If not use the jimmy to unclip the others.
      Ask FixBot
    3. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing buttons and Exposing the circuit: step 3, image 1 of 2 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing buttons and Exposing the circuit: step 3, image 2 of 2
      • The Buttons are easily removed. The Volume Touch pad is also seen here; it is attached by glue.
      Ask FixBot
    4. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the first Circuit Board: step 4, image 1 of 3 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the first Circuit Board: step 4, image 2 of 3 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the first Circuit Board: step 4, image 3 of 3
      • Use the Jimmy to prop the circuit board from the glue attached to the casing. Becareful of the ribbon attached. The circuit board will come out away from the ribbon if you remove it from the glue.
      Ask FixBot
    5. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Ribbon Cable from Circuit: step 5, image 1 of 2 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Ribbon Cable from Circuit: step 5, image 2 of 2
      • Once you have the Circuit out of the glue you will see the shown Ribbon attachment clip moved up to be removed. Second picture the board is removed.
      Ask FixBot
    6. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Ribbon Sensor and Battery Compartment: step 6, image 1 of 3 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Ribbon Sensor and Battery Compartment: step 6, image 2 of 3 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Ribbon Sensor and Battery Compartment: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • The Sensor Ribbon is carefully peeled away from the glue. There are two options available to get the battery compartment out. You can either use the Tweezers and push near the ribbon cable or you can use the tweezers to push from the other end inside and under the Sensor place as seen in the picture.
      Ask FixBot
    7. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Battery from the housing: step 7, image 1 of 3 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Battery from the housing: step 7, image 2 of 3 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Battery from the housing: step 7, image 3 of 3
      • From here you can remove the Single Phillips Screw using the Phillips 00 Driver Bit. This will let you pry the circuit and battery from the Glue . You can lift the Battery from the Circuit board as it is made to lift upward and away from the board.
      Ask FixBot
    8. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Battery and Overall Component Picture: step 8, image 1 of 3 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Battery and Overall Component Picture: step 8, image 2 of 3 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Battery and Overall Component Picture: step 8, image 3 of 3
      • Insert wisdom here.
      Ask FixBot
Finish Line
5 other people completed this guide.
Kevin Jones
1,332 Reputation
2 Guides authored
9 Guide Comments
I have one slight problem. I opened my remote, now i cant put it back together. The clamp near the charging port just wont get back into place. Nothing is broken. i checked, all clamps are there, but this one just wont slide back in to let me close back the remote. Any tip ?
Remus C - Reply Share
YouTube Comment
YouTube Comment
I would double check the female Clamp end on the bottom part. You my have broken the receiving end of the clamp.
YouTube Comment
Thank you for the reply. Sadly both of clamps were ok. I managed to fix by bending the male clamp in the outside position. Also, the female clamp was made of aluminum, so breaking it was impossible. I finally closed it somehow, but it still has a little wiggle on the sides. Well, thats about all that can be done.
Kevin Jones - Reply Share
Has anyone else experienced that the microphone stops working? I’m thinking maybe it could be fixed by opening it up and.. ?
Thomas Novin - Reply Share
Where i can buy the battery?
Samir Selmanovic - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 177
All Time: 13,641
