Up to 20% off select tools
NEC Turbo Express Disassembly
Views: 2.1K
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
68
All Time:
2,147
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
    1. NEC Turbo Express Disassembly, Separate front/rear shells: step 1, image 1 of 3 NEC Turbo Express Disassembly, Separate front/rear shells: step 1, image 2 of 3 NEC Turbo Express Disassembly, Separate front/rear shells: step 1, image 3 of 3
      • Remove battery cover
      • Remove 6 PH0 screws
      • Do not attempt to separate the two halves
      • Disconnect the 2 FFC ribbon cables and wire connector
      • There's another ribbon cable, not shown in photo, next to the white one
      • You can now separate the two halves
      Ask FixBot
    2. NEC Turbo Express Disassembly, Disconnect TV tuner FFC cable: step 2, image 1 of 3 NEC Turbo Express Disassembly, Disconnect TV tuner FFC cable: step 2, image 2 of 3 NEC Turbo Express Disassembly, Disconnect TV tuner FFC cable: step 2, image 3 of 3
      • Disconnect FFC ribbon cable
      Ask FixBot
    3. NEC Turbo Express Disassembly, Remove TV Tuner Port: step 3, image 1 of 3 NEC Turbo Express Disassembly, Remove TV Tuner Port: step 3, image 2 of 3 NEC Turbo Express Disassembly, Remove TV Tuner Port: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • With a pair of tweezers, pinch the retaining tabs inward and push through the shell
      • This can be done with the rear motherboard still in place.
      Ask FixBot
    4. NEC Turbo Express Disassembly, Disconnect battery cable: step 4, image 1 of 2 NEC Turbo Express Disassembly, Disconnect battery cable: step 4, image 2 of 2
      • Disconnect cable
      Ask FixBot
    5. NEC Turbo Express Disassembly, Disconnect battery cable: step 5, image 1 of 2 NEC Turbo Express Disassembly, Disconnect battery cable: step 5, image 2 of 2
      • Remove tape
      • Keep it close to reuse during reassembly
      Ask FixBot
    6. NEC Turbo Express Disassembly, Remove rear PCB: step 6, image 1 of 3 NEC Turbo Express Disassembly, Remove rear PCB: step 6, image 2 of 3 NEC Turbo Express Disassembly, Remove rear PCB: step 6, image 3 of 3
      • Remove PH0 screw
      • Gently lift the PCB up
      • Remove 3 PH2 screws
      • You can now remove the entire rear PCB
      Ask FixBot
    7. NEC Turbo Express Disassembly, Disconnect speaker: step 7, image 1 of 3 NEC Turbo Express Disassembly, Disconnect speaker: step 7, image 2 of 3 NEC Turbo Express Disassembly, Disconnect speaker: step 7, image 3 of 3
      • Disconnect wire plug
      Ask FixBot
    8. NEC Turbo Express Disassembly, Remove front PCB: step 8, image 1 of 2 NEC Turbo Express Disassembly, Remove front PCB: step 8, image 2 of 2
      • Remove 3 PH0 screws
      • You can now remove the front PCB
      Ask FixBot
    9. NEC Turbo Express Disassembly, Remove speaker: step 9, image 1 of 2 NEC Turbo Express Disassembly, Remove speaker: step 9, image 2 of 2
      • Remove 2 PH0 screws
      • You can now remove the speaker
      Ask FixBot
    10. NEC Turbo Express Disassembly, Remove screen: step 10, image 1 of 1
      • Remove 4 PH0 screws
      • You can now remove the screen
      Ask FixBot
Author
with
Navy Vet 2015
8,435 Reputation
15 Guides authored
1 Guide Comment
Could you tell me the size of the 6 exterior screws? I lost mine. Thanks.
The Machine Shed - Reply Share
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 68
All Time: 2,147
