Introduction
This guide is to display how to replace various parts in a cash register terminal and some minor maintenance.
You will need the security key that came with the register to unlock the front panel.
There are two screws in the back to release the cover.
Disconnect all cables that are coming from the power supply.
Be sure to check the normal 24 and 4 pin power supply cables. But also look around for any supporting components that require power.
Remove the power supply by pulling it towards yourself . (As is you are looking down at the device).
One Comment
I have a ncr pocono d-nr6-d-021 v1.0 motherboard with which i am batteling to connect the front panel connectors onto the board. As this was a ATM board with connectors to a front panel i now use it as a PC DESKTOP .The motherboard has the following starting from the leftf audio -10 pins ,panel 1 - 10 pins missing pin 3j2 - 16 pins missing pin 11The connectors isPower led+ (green),power led- (white)reset switch (cream & white),Hdd Led, (yellow & white)HD audio, (black, dark blue, yellow, white, orange,green,purple, red) _____That is connectedPower switch (black & white),USb (red red white white green green black black). ______That is connected.Hope you can help me.Thanks.
