Mounting and dismounting the tablet
  1. Mounting and dismounting the tablet, Mounting and dismounting the tablet: step 1, image 1 of 1
    • The hull seen from the front.
  2. Mounting and dismounting the tablet: step 2, image 1 of 1
    • The case seen from the back, with the jacks where to connect your handsets
  3. Mounting and dismounting the tablet: step 3, image 1 of 1
    • Enough to redo a shell in case of problems, but without the feet.
    • The T14 snake-eyes tip to disassemble the facade.
    • Collars to block the jacks of your handsets under the shell.
    • Replacement snake eyes M6 screws, M6 inserts to remake a shell
  4. Mounting and dismounting the tablet: step 4, image 1 of 1
    • Use the tip to disassemble the screws.
    • DO IT MANUALLY!!!
    • Not to the screwdriver, because it will rip. And the tip will damage the facade.
  5. Mounting and dismounting the tablet: step 5, image 1 of 1
    • To block the jacks of the handsets: make a knot on the collar.
    • Thus, users will not be able to disconnect the handsets
  6. Mounting and dismounting the tablet: step 6, image 1 of 1
    • If you want to redo a shell:
    • You have to cut the inserts, and pierce the bottom to pass the usb plug and the jack that connects to the tablet.
    • Take the model delivered as an example
  7. Mounting and dismounting the tablet: step 7, image 1 of 1
    • To change the content of the micro SD card:
    • You must disassemble the facade, remove the tablet from the shell and open the "SD card" hatch
    • Create a file named: sexbreizh.avi
    • AVI container, mp3 audio codec, xvid video codec
    • Audio bitrate: 44100
    • Video rate: 8000
7 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
AFPD Conception
244 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 115
All Time: 2,250
