Up to 20% off select tools
Mounting Plate Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
0
Past 7 Days:
10
Past 30 Days:
45
All Time:
1,743
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If you have trouble with your mount plate or want to replace it, this guide will give you detailed steps to follow in order to successfully replace your mounting plate. This replacement should take approximately 5-10 minutes to complete.
    1. Mounting Plate  Replacement, Mounting Plate: step 1, image 1 of 1
      • Hold Ring Spotlight Cam and hold it backward to you.
      Ask FixBot
    2. Mounting Plate  Replacement: step 2, image 1 of 1
      • Remove the screw using the screwdriver and head tool PH00.
      Ask FixBot
    3. Mounting Plate  Replacement: step 3, image 1 of 1
      • Open the top lid.
      Ask FixBot
    4. Mounting Plate  Replacement: step 4, image 1 of 3 Mounting Plate  Replacement: step 4, image 2 of 3 Mounting Plate  Replacement: step 4, image 3 of 3
      • Press the mounting plate button and slide upwards.
      Ask FixBot
Author
with
Damaris Aguirre
31 Reputation
2 Guides authored
1 Guide Comment
Hello, hope you are doing well. Does anyone know if we can buy a replacement mounting plate for the Ring Spotlight Cam Battery? Mine is cracked and Ring doesn’t seem to sell replacements. Thanks!
Suresh Ram - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 45
All Time: 1,743
