Motorola XOOM 2 Media Edition Speakers Replacement
  1. Motorola XOOM 2 Media Edition Speakers Replacement, Motorola XOOM 2 Media Edition Disassembly: step 1, image 1 of 2 Motorola XOOM 2 Media Edition Speakers Replacement, Motorola XOOM 2 Media Edition Disassembly: step 1, image 2 of 2
    • Power off the device before beginning disassembly.
    • Remove six 2.7mm Torx #3 screws.
  2. Motorola XOOM 2 Media Edition Speakers Replacement: step 2, image 1 of 2 Motorola XOOM 2 Media Edition Speakers Replacement: step 2, image 2 of 2
    • There is adhesive attached to the underside of the back panel. Gradually lift the panel to avoid bending it out of shape.
    • Pry off the back panel using a plastic opening tool.
    • Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
  3. Motorola XOOM 2 Media Edition Speakers Replacement: step 3, image 1 of 3 Motorola XOOM 2 Media Edition Speakers Replacement: step 3, image 2 of 3 Motorola XOOM 2 Media Edition Speakers Replacement: step 3, image 3 of 3
    • Pry off the black cover gradually using a plastic opening tool.
  4. Motorola XOOM 2 Media Edition Speakers Replacement, Speakers: step 4, image 1 of 3 Motorola XOOM 2 Media Edition Speakers Replacement, Speakers: step 4, image 2 of 3 Motorola XOOM 2 Media Edition Speakers Replacement, Speakers: step 4, image 3 of 3
    • Using the tweezers, gently pull up the connector of each of the speakers.
  5. Motorola XOOM 2 Media Edition Speakers Replacement: step 5, image 1 of 2 Motorola XOOM 2 Media Edition Speakers Replacement: step 5, image 2 of 2
    • Once the connector is removed, use the tweezers to pull up the speaker from its plastic socket on both of the speakers.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 7
All Time: 174
