Motorola V60c Motherboard Replacement
  1. Motorola V60c Motherboard Replacement, Battery: step 1, image 1 of 2 Motorola V60c Motherboard Replacement, Battery: step 1, image 2 of 2
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Motherboard Replacement: step 2, image 1 of 2 Motorola V60c Motherboard Replacement: step 2, image 2 of 2
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Motherboard Replacement, Motherboard: step 3, image 1 of 1
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Motherboard Replacement: step 4, image 1 of 2 Motorola V60c Motherboard Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to pry up back cover from the two side clips.
    • NOTE: sticker might be attached to rest of phone.
  5. Motorola V60c Motherboard Replacement: step 5, image 1 of 1
    • Remove the back cover.
  6. Motorola V60c Motherboard Replacement: step 6, image 1 of 2 Motorola V60c Motherboard Replacement: step 6, image 2 of 2
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board to remove.
Ryan Kuroiwa
1 Reputation
5 Guides authored
Cal Poly, Team 25-86, Amido Spring 2010 Member of Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,352
