Repairing Motorola V325 Keypad
  1. Repairing Motorola V325 Keypad, Battery: step 1, image 1 of 1
    • Flip the phone over so that the back is visible.
    • Push down on the silver button using your fingernail or thumbnail. Push down all the way until the button stops.
  2. Repairing Motorola V325 Keypad: step 2, image 1 of 3 Repairing Motorola V325 Keypad: step 2, image 2 of 3 Repairing Motorola V325 Keypad: step 2, image 3 of 3
    • While holding down the silver button, simultaneously pull downward on the rear cover, then lift it off to reveal the battery.
    • This will only take a moment to do.
  3. Repairing Motorola V325 Keypad: step 3, image 1 of 3 Repairing Motorola V325 Keypad: step 3, image 2 of 3 Repairing Motorola V325 Keypad: step 3, image 3 of 3
    • Using your thumbnail and fingernail, grip the battery where indicated as "pull here" and lift the battery upward, starting at that side.
    • Remove the battery completely by lifting it straight out of the phone.
  4. Repairing Motorola V325 Keypad: step 4, image 1 of 1
    • When replacing the battery, ensure that the side that has the "pull here" arrows goes toward the bottom of the phone. Place the side of the battery with the metallic contacts in toward the inside of the phone, making a full connection with the contacts within the phone (shown in the red rectangle).
  5. Repairing Motorola V325 Keypad, Rear Panel: step 5, image 1 of 3 Repairing Motorola V325 Keypad, Rear Panel: step 5, image 2 of 3 Repairing Motorola V325 Keypad, Rear Panel: step 5, image 3 of 3
    • Using a small flat head screwdriver or your fingernail, remove the rubber covers near the top of the phone
  6. Repairing Motorola V325 Keypad: step 6, image 1 of 3 Repairing Motorola V325 Keypad: step 6, image 2 of 3 Repairing Motorola V325 Keypad: step 6, image 3 of 3
    • There are four Torx screws located on the four corners of the rear panel
    • Remove all four screws using the T6 Torx Screwdriver.
  7. Repairing Motorola V325 Keypad: step 7, image 1 of 3 Repairing Motorola V325 Keypad: step 7, image 2 of 3 Repairing Motorola V325 Keypad: step 7, image 3 of 3
    • Unscrew the antenna.
    • Remove the antenna protective tubing
  8. Repairing Motorola V325 Keypad: step 8, image 1 of 3 Repairing Motorola V325 Keypad: step 8, image 2 of 3 Repairing Motorola V325 Keypad: step 8, image 3 of 3
    • There are four light gray tabs located around the phone (two on each side)
    • Using your finger nail or a flat head screwdriver, pull the gray tab away from the body while simultaneously lifting upward on the black rear panel.
    • Once all four tabs are removed, lift up the back panel to reveal the interior logic board.
  9. Repairing Motorola V325 Keypad, Keypad: step 9, image 1 of 1
    • Make sure the phone appears as shown after removing the rear panel.
  10. Repairing Motorola V325 Keypad: step 10, image 1 of 3 Repairing Motorola V325 Keypad: step 10, image 2 of 3 Repairing Motorola V325 Keypad: step 10, image 3 of 3
    • Gently lift up the logic board by placing your index finger at the top while keeping your thumb at the bottom of the phone for leverage.
  11. Repairing Motorola V325 Keypad: step 11, image 1 of 3 Repairing Motorola V325 Keypad: step 11, image 2 of 3 Repairing Motorola V325 Keypad: step 11, image 3 of 3
    • Gently remove the keypad from the phone by getting a grip on the top of the keypad and slowly peeling it top to bottom.
Stephanie
1 Reputation
2 Guides authored
Cal Poly, Team 4-15, Forte Winter 2010 Member of Cal Poly, Team 4-15, Forte Winter 2010
CPSU-FORTE-W10S4G15
5 Members
8 Guides authored
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 13
All Time: 1,173
