Motorola V2397 Front Cover Replacement
    1. Motorola V2397 Front Cover Replacement, Battery: step 1, image 1 of 3 Motorola V2397 Front Cover Replacement, Battery: step 1, image 2 of 3 Motorola V2397 Front Cover Replacement, Battery: step 1, image 3 of 3
      • Press and hold the button on the battery cover
      • Pull the battery cover down and out to remove it
      Ask FixBot
    2. Motorola V2397 Front Cover Replacement: step 2, image 1 of 2 Motorola V2397 Front Cover Replacement: step 2, image 2 of 2
      • Remove the batteries by pulling them away from the phone
      Ask FixBot
    1. Motorola V2397 Front Cover Replacement, Back Cover: step 3, image 1 of 2 Motorola V2397 Front Cover Replacement, Back Cover: step 3, image 2 of 2
      • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
      Ask FixBot
    2. Motorola V2397 Front Cover Replacement: step 4, image 1 of 2 Motorola V2397 Front Cover Replacement: step 4, image 2 of 2
      • Use your fingers or a spudger to remove the back cover
      Ask FixBot
    1. Motorola V2397 Front Cover Replacement, Side Buttons: step 5, image 1 of 2 Motorola V2397 Front Cover Replacement, Side Buttons: step 5, image 2 of 2
      • Lift and remove buttons by hand
      Ask FixBot
    1. Motorola V2397 Front Cover Replacement, Phone: step 6, image 1 of 2 Motorola V2397 Front Cover Replacement, Phone: step 6, image 2 of 2
      • Place your plastic opening tool in between the motherboard and the front cover of the phone
      • Apply a small force to lift the motherboard away from the front cover
      Ask FixBot
    1. Motorola V2397 Front Cover Replacement, Keypad: step 7, image 1 of 3 Motorola V2397 Front Cover Replacement, Keypad: step 7, image 2 of 3 Motorola V2397 Front Cover Replacement, Keypad: step 7, image 3 of 3
      • Grip the top of the rubber keypad with your thumb and index finger
      • While holding the keypad start to peel it back from the front cover until the keypad is completely detached
      Ask FixBot
    1. Motorola V2397 Front Cover Replacement, Speaker: step 8, image 1 of 2 Motorola V2397 Front Cover Replacement, Speaker: step 8, image 2 of 2
      • Use the iFixit opening tool to lift the speaker off the front cover.
      Ask FixBot
    1. Motorola V2397 Front Cover Replacement, Front Cover: step 9, image 1 of 2 Motorola V2397 Front Cover Replacement, Front Cover: step 9, image 2 of 2
      • Once the motherboard, speaker, and keypad have been removed you should have the front cover by itself
      Ask FixBot
Connor
201 Reputation
2 Guides authored
USF Tampa, Team 1-6, Sullivan Winter 2015 Member of USF Tampa, Team 1-6, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G6
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 28
All Time: 328
