Motorola V180 Motherboard Replacement
  1. Motorola V180 Motherboard Replacement, Battery: step 1, image 1 of 3 Motorola V180 Motherboard Replacement, Battery: step 1, image 2 of 3 Motorola V180 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
  2. Motorola V180 Motherboard Replacement, Motherboard: step 2, image 1 of 3 Motorola V180 Motherboard Replacement, Motherboard: step 2, image 2 of 3 Motorola V180 Motherboard Replacement, Motherboard: step 2, image 3 of 3
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  3. Motorola V180 Motherboard Replacement: step 3, image 1 of 2 Motorola V180 Motherboard Replacement: step 3, image 2 of 2
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard by lifting it up out of the keypad.
Tyler Knisley
1 Reputation
7 Guides authored
Cal Poly, Team 6-16, Maness Spring 2010 Member of Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,565
