Introduction
Use this guide to replace the keypad.
Turn off your phone before beginning disassembly.
Remove the phone back cover by firmly pushing down on the black tab located at the top center of the Motorola Slvr L7.
Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
De-route the antenna cable by pulling it out.
Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
The cover is attached by several clips, so some force may be required, especially to unclip the first clip.
Be careful not to loose the round plastic piece that covers the microphone.
Starting at the top, insert the flat end of a spudger and pry the frame of the phone.
The frame is attached by several clips, so some force may be required to dislodge the first clip.
Work your tool around the entire edge of the phone, moving as soon as you hear a clip come undone, to avoid breaking the frame.
