Motorola Slvr L7 Keypad Replacement
  1. Motorola Slvr L7 Keypad Replacement, Keypad: step 1, image 1 of 1
    • Push down on the black tab located at the top center of the Motorola phone
  2. Motorola Slvr L7 Keypad Replacement: step 2, image 1 of 1
    • Remove the battery by pulling the battery from the top center
  3. Motorola Slvr L7 Keypad Replacement: step 3, image 1 of 1
    • Remove the four (4) T6 Torx screws from the rear metal plate.
  4. Motorola Slvr L7 Keypad Replacement: step 4, image 1 of 2 Motorola Slvr L7 Keypad Replacement: step 4, image 2 of 2
    • Insert the flat end of a spudger and pry the metal cover up off the phone
  5. Motorola Slvr L7 Keypad Replacement: step 5, image 1 of 2 Motorola Slvr L7 Keypad Replacement: step 5, image 2 of 2
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
  6. Motorola Slvr L7 Keypad Replacement: step 6, image 1 of 1
    • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
  7. Motorola Slvr L7 Keypad Replacement: step 7, image 1 of 1
    • Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • The cover is attached by several clips, so some force may be required, especially to unclip the first clip.
    • Be careful not to loose the round plastic piece that covers the microphone.
  8. Motorola Slvr L7 Keypad Replacement: step 8, image 1 of 2 Motorola Slvr L7 Keypad Replacement: step 8, image 2 of 2
    • Remove the 2 newly exposed T6 screws
  9. Motorola Slvr L7 Keypad Replacement: step 9, image 1 of 2 Motorola Slvr L7 Keypad Replacement: step 9, image 2 of 2
    • Starting at the top, insert the flat end of a spudger and pry the frame of the phone.
    • The frame is attached by several clips, so some force may be required to dislodge the first clip.
    • Work your tool around the entire edge of the phone, moving as soon as you hear a clip come undone, to avoid breaking the frame.
  10. Motorola Slvr L7 Keypad Replacement: step 10, image 1 of 2 Motorola Slvr L7 Keypad Replacement: step 10, image 2 of 2
    • Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
Jorge Trujillo
520 Reputation
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 17
All Time: 5,713
